2.6 install insues
Answered Question
Oct 5th, 2009
I have taken over an install and have come across some issues:
CS and RME LMS2.2 were installed. When trying to install CM, the install tries to stop the dmgtd process but apparently fails. I then tried to install LMS 2.5 ontop of this but have thesame issues (see attached).
If I try to manually kill these processes, a new process is created. How tdo I terminate them to continue the install?
Cheers in advance!
Correct Answer by Joe Clarke about 7 years 4 months ago
Run this command:
kill -9 1021 16012 16006 16007 16008 16009
That should kill off all of the remaining Apache processes.
Overall Rating: 5 (3 ratings)
Joe Clarke Mon, 10/05/2009 - 20:58
You can simply kill these process with kill -9 (e.g. kill -9 1021). The problem with dmgtd not being able to kill off all apps when LMS is installed into a custom NMSROOT is fixed in Common Services 3.0.6 which is part of LMS 2.6 SP1.
pieterddejong Tue, 10/06/2009 - 14:55
Thanks for your help. I really appreciate it. I'm more IOS focused and not Solaris. The organisation I work with depict that the folder structure unfortunately. I followed your advise but unfortunately the processes start up again (see attached). I can't uninstall or do anything until I kill these. Any other tips perhaps?
Cheers in advance
Joe Clarke Tue, 10/06/2009 - 16:05
Daemon Manager must still be running. Post the entire ps -efl output.
Correct Answer
Joe Clarke Tue, 10/06/2009 - 16:41
Run this command:
pieterddejong Tue, 10/06/2009 - 18:41
Thank you!
That has resolved my issue. Will continue on the install and hold thumbs...
Marvin Rhoads Mon, 10/05/2009 - 21:10
First off you are upgrading a very old version with an not quite as old but still old (~ 4 years old) version. LMS 3.2 is the current release. Unless there's a lot of content you need on the old server, I'd think a new clean install would serve you better.
How are you killing the processes? You should use /etc/init.d/dmgtd stop.
I notice the localhost address is being used. This is not generally recommended for Ciscoworks server access. Use the fqdn or real IP address instead.
