100M (bidi) sfp not working in catalyst 2960
Oct 6th, 2009
I installed a GLC-FE-100BX-U transceiver
in a C2960-8TC-L switch running the latest IOS, but the interface doesn't come up.
Do I have to configure 100M sfp support somehow?
sh int shows "media type is 1000BaseLX SFP" at the moment.
Giuseppe Larosa Tue, 10/06/2009 - 00:29
  • Hall of Fame,
    Founding Member
Hello Alex,
have you placed the companion type of SFP on the other side of the link?
see
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#support6
no special settings are needed and sh int type x/y should report the right SFP type
example
sh int gi0/25 | inc SFP
Full-duplex, 100Mb/s, link type is auto, media type is 100BaseFX SFP
this is from a 3560
in the link your model is not listed among the ones supporting 100M SFPs see table of supported models
Hope to help
Giuseppe
glen.grant Tue, 10/06/2009 - 03:33
  • Purple, 4500 points or more
If these are dual media type ports you may have to specify SFP instead of RJ45 .
ae3997 Tue, 10/06/2009 - 05:02
I have tried both media type "auto-select" and "sfp" configurations.
1000M SFP:s work fine in the switch.
Oddly enough, the switch in the other end of this connection shows link up on the port connected to the 2960.
