SIP Trunk between CUCM and SPA9000
Paolo Bevilacqua Fri, 10/09/2009 - 11:52
  • Hall of Fame,
    Founding Member
Should work, but I recommend you only use true cisco GWs for most reliable and feature-rich results.
Abdulbaseer Mohammed Tue, 11/03/2009 - 12:35
  • Silver, 250 points or more
How are you plannign to use it?
It should integrate fine and SIP trunk is the best way as SPA is all SIP with few other options.
You can use it completely independent as well just configure your translations on cucm.
Please rate helpful posts.
Baseer.
