Pls guide for the configuration for topology attached
Oct 6th, 2009
Dear Netpros,
I am attaching a Rough Topology Dia.
There are around 30 Vlans on Netwrok.
Netwrok should be fully Redundant and managable.
Can you suggest me the configuration guide ?
Should we use Vlan creation and intervlan routing on Core layer or on Distribution layer ?
How ?
Pls reply ......
Dipesh P.
ohassairi Tue, 10/06/2009 - 01:44
i suggest :
c4500 will be distribution and core layer. here you will define VLANs (VTP server) and SVI , routing, ACL,..., STP (mst mode)
c3560 will be access layer (L2 only). (VTP clients) here you will attribute ports to VLANS.
of course uplinks will be trunks
a typical config can be found here:
other usefull commands are in the same web page
Dipesh Patel Wed, 10/07/2009 - 21:23
Dear ohassairi,
I have one more confusion.
How to configure any vlan i.e vlan 5 Ip address if TWO SUP V with 2 10 GE card in one 4510R core sw and with high Availability are there?
Int Vlan 5
ip address alt
Pls suggest.
Pls give me the sample config for one vlan 5.
Leo Laohoo Tue, 10/06/2009 - 14:29
L2 switch: 2975 or 3750
L3 switch: If you want 2 x 10 Gb and SFP, look at WS-C3560E-12D or -12SD.
SANTHOSHKUMAR S... Wed, 10/07/2009 - 22:22
Dear Dipesh ,
you can have your VLAN splitted across between your core Switches ( 15+15) by enabling HSRP among the VLAN for High Availability .
Similarly PVST on Access layer to ensure uplink between two core switches ,
look the sample config attached .
Dipesh Patel Thu, 10/08/2009 - 00:44
Dear sanvaishu ,
Thanks For reply...
thats good but I am asking about what if I have 2 nos of SUP in the same SW 4510R?
Dipesh P.
Dipesh Patel Thu, 10/08/2009 - 06:25
hi ohassairi,
It means that :
If I have 2 nos of Sup and config is for example :
int vlan 5
Ip address
now Active sup i will remove than automatically this Ip will be used for other SUP?
M i correct ?
Dipesh P.
