IP phone 7920 Problem With 1252 AP
Oct 6th, 2009
Dear all
I knew that 7920 is not supported by cisco to work with 1252 AP. (7920 can't authenticate with the access point although that 7921 is working fine)
I red in other conversations that the problem in TKIP encryption , but it doesn't work with WEP encryption or no encryption.
So any one can help me about this topic?!!
Walidhi10 Fri, 10/09/2009 - 10:08
Hi all
i didn't get any reply
I heared that there are some cases that IP phone worked with 1250 AP but don't know how.
Also there are problems with laptops of 802.11b cards (Laptops can't authenticate with 1250 APs)
Waiting your replys
amrezzat911eg Sun, 10/11/2009 - 09:36
although we faced the same problem with a big client; the TAC engineer has just told us that WEP should work ; we tested it ; and it didn't ;
I hope it works fine after upgrading the phone firmware;(I am using wism 6.0.182.0)
does any one got any other ideas
Amr Ezzat (Egypt)
Robert.N.Barrett_2 Mon, 10/12/2009 - 05:14
It's not your exact situation, but I know of a company running 6.0 WLC code with 1140 APs using their 7920's with WEP.
Make sure you enable the "Platinum" level of service in the WLAN definition.
amr.momtaz Mon, 10/12/2009 - 23:23
this is different, we are talking about the 1250 AP in specific.
dlawson001 Tue, 10/13/2009 - 06:08
Its possible that Cisco simply doesn't allow the interaction of these two at a software level. While it should be permitted they often act like Apple and prevent consumers from interacting two devices that are compatible only on certain levels. Saves them tech support time.
amrezzat911eg Tue, 10/13/2009 - 10:48
as per my nice colleague Amr Momtaz the relase of the 1250 said that it won't support the 7920 phones ; I think this is a sales goal ; not related to technical issues;
Amr Ezzat (Egypt)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
