ACL
Answered Question
Oct 6th, 2009
our goal is to restrict RDP and all type of remote connection from internet to our mail server and allow only required ports
access-list 114 permit tcp any host 83.xxx.xx.xx eq domain
access-list 114 permit tcp any host 83.xxx.xx.xx eq smtp
access-list 114 permit tcp any host 83.xxx.xx.xx eq pop3
access-list 114 permit tcp any host 83.xxx.xx.xx eq 995
access-list 114 deny ip any any
fastethernet 0/1
inteface serial0/0/0
ip address 193.55.xx.xxx 255.255.255.252
ip access-group 114 in/out ????????????
in which interface should we apply this ACL , and how it should be implemented in or out
any help will be most appreciated
thank you
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Alaa,
I think you should apply this inbound on your serial interface but I agree it could be applied outbound DMZ interface as well.
>> notice that if the ACL was written differently it couldn't be applied anywhere. <
ignore this sometimes I make useless comments
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Tue, 10/06/2009 - 04:46
Are you the end user ?
This kind of configuration, and more security advice would be better done by a reputable consultant or certified partner.
Giuseppe Larosa Tue, 10/06/2009 - 04:49
Hello Ala,
I hope you are fine.
if host 83.xx.xx.xx is outside your network in the internet you can apply this ACL:
or inbound on internal interface
int fas0/1
OR
in outbound on external interface
int se0/0/0
ip access-group 114 out
Edit:
I had missed the first line of your post
if so 83.xx.xx.xx is your server and the ACL can only be applied inbound on serial interface
int ser0/0/0
Hope to help
Giuseppe
alaeldien Tue, 10/06/2009 - 20:35
Hello Guiseppe
Thank you for always been on the spot
i also missed very important part of my configs
int fastethernet0/1 (Configured as DMZ with public ip addressEs)
ip address 83.xxx.xxx.xx 255.255.255.28
so do you think i need to apply the ACL in serial inbound or fast ethernet outboud ???
>>>>> notice that if the ACL was written differently it couldn't be applied anywhere. < ?? do you mean if its extended, can you clarify your point, it seem to be very important notice.
thank you
Alaa
Correct Answer
Giuseppe Larosa Wed, 10/07/2009 - 10:16
Hello Alaa,
Hope to help
Giuseppe
YANGCCIE4 Tue, 10/06/2009 - 06:05
Hi, If this is your network topology,
rt e0 ------ f0/2 SW f0/1 ---- exchange_serv
you can apply the access-list in f0/2
this is the part of my configuration.
hostname rt
interface Ethernet0/0
ip address 1.1.123.1 255.255.255.0
half-duplex
hostname sw
interface FastEthernet0/1
switchport mode access
interface FastEthernet0/2
access-list 114 permit tcp any host 1.1.123.5 eq domain
access-list 114 permit tcp any host 1.1.123.5 eq 993
access-list 114 permit tcp any host 1.1.123.5 eq smtp
access-list 114 permit tcp any host 1.1.123.5 eq pop3
access-list 114 deny ip any host 1.1.123.5
YANGCCIE4 Tue, 10/06/2009 - 06:48
as p.bevilacqua and giuslar said,the network topology is different the configuration will be different, you also can apply the acl in the pix or asa.
Hope this help.
Yang
