UCCX 5.0.2 in HA on VMWare Workstation
Oct 6th, 2009
AT the moment I'm trying to install UCCX 5.0.2 in HA on VMWare Workstation. I am doing it in the way that I am doing a restore procedure on IPCC1. After some time procedure asks me to add the IPCC2 into the cluster. When I try to do that I get the following message:
The Add to cluster operation could not be performed due to insufficient space for database replication process. Please do the following and then perform the Add to cluster operation again. If Microsoft SQL Server is already installed, execute database expansion operation directly. If not, install Microsoft SQL Server and then perform the database expansion. To perform the Database expansion, run the DB expansion utility located at (C:\Program Files\wfavvid\execscript.exe)
SQL server is installed and the procedure doesn't help. I gave the server recomended 80GB of hard. Any ideas?
Any suggestion is appreciated...
Goran Pilat
