SYSLOG
Answered Question
Oct 6th, 2009
I can't see in the syslog when a user accesses a Cisco 6509 (12.2 (17r) S4). This is the configuration that I used.
logging xxx.xxx.xxx.xxx
logging trap informational
logging facility local6
logging source-interface Vlan99
logging on
Someone can help me?
Correct Answer by yjdabear about 7 years 7 months ago
It's an enhancement in IOS 12.3(4)T and later:
login on-failure log
login on-success log
with pre-requisite of "login block-for seconds attempts tries within seconds"
Otherwise, you need to look at the logs of your AAA backend.
Overall Rating: 5 (1 ratings)
Correct Answer
yjdabear Tue, 10/06/2009 - 08:06
  • Gold, 750 points or more
emiliobalmon Tue, 10/06/2009 - 22:41
it works correctly. Now I can see from what address logged and if the authentication was correct or incorrect.
It seems strange that i can not see that user is authenticated. Is there any way to do this?
Thanks a lot
