ECC variable
wplantier
how do I create a ECC variable for voicemails coming in?
geoff
Level 10
Level 10
In the ICM Config tool, choose List Tools and then Expanded Call Variables List and create your variable. Name, type, num of chars if a string. Check space usage. Keep the name short - it takes up space. Don't follow the Cisco naming convention here - something short and sweet.
Go back to Script Editor, reload the configuration, then add a Set node. Choose the new variable and give it a value.
Geoff
