integrate AD with CUCM 7.X
Answered Question
Oct 6th, 2009
Hi all,
We have a CUCM 7.X, and want to use Active Directory for end user's specific attributes like controlled devices, personal phone book.
The normal syncronization is works and the end user authentication too.
I want store the users' controlledDevices attributes in the Active Directory too.
I didn't find any config guide or information about this. I found just for the 3.X version. Where can I find a guide that is show me how to do it.
Is there any patch or program for this or have to do this manually (I mean download the cisco schema, extend the AD with this schema, and configure the callmanager to use the AD for this specific attributes).
I think this is possible (cos in the 3.X it is) but I didn't find anything.
please help!
Thank you.
Gabor
Correct Answer by Jaime Valencia about 7 years 5 months ago
Linux appliances do not have any AD plugin and do not extend the AD schema (CUCM specific info is only in CUCM server), that was only on Windows versions
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 10/06/2009 - 08:01
  • Cisco Employee,
  • Hall of Fame,
    2011
java
hegegabor Wed, 10/07/2009 - 00:25
hmm, it is bad news...
and why? Is it too complex to extend?
thank you,
Gabor
Jaime Valencia Wed, 10/07/2009 - 06:20
  • Cisco Employee,
  • Hall of Fame,
    2011
No, simply because Linux appliances pull the info from LDAP into the CUCM server and there is no need. You can add the necessary fields within the copy CUCM has and leave LDAP untouched.
java
hegegabor Wed, 10/07/2009 - 06:49
I don't understand you...
first of all, I don't need extend the AD schema as you say. okay
but where can I set the necessary fields (controlled devices...). Is the CUCM 7.X support to store this attributes in AD?
How can I do this?
thank you.
shane.orr Sat, 10/10/2009 - 14:58
  • Silver, 250 points or more
hegegabor Mon, 10/12/2009 - 07:11
hi,
I have read these before, but thank you.
I know how can I configure, I just didn't know it is possible to store cisco specific informations external in 7.x. But I see no.
Gabor
shane.orr Mon, 10/12/2009 - 07:14
OK, sorry, I read your original post after I had replied and figured you might have already had that information.
To my knowledge you are not able to store information in AD like you were able to do with older versions of Call Manager.
