DFM on LMS 2.6
Oct 6th, 2009
Hello , Dears All,
We would like to retrieve a log where there is a event associated to a device under RME.
I have read this document :dfm_ug.pdf and there is a lot of logs associated.
In which file.log can we see event by device ?
Joe Clarke Tue, 10/06/2009 - 09:01
You could enable DFM Event Promulgation debugging, then look at the DFM epa and EPM logs under NMSROOT/log/dfmLogs. These are not designed for user consumption, though. There is really no such log like there was with the DFM 1.2 file notifier. The closest thing you could do is setup a Syslog Notification Subscription which sends all event notifications to a syslog server. Then, look through the associated syslog log to see the events.
richard.tetu Mon, 10/12/2009 - 02:29
Thanks i will try that.
Anyway, I think that we ll open the Syslog file even if it's a big file.
Talk to you later.
