7960 sip factory default
Oct 6th, 2009
Hi All,
I've inherited a few older 7960 SIP phones and I am in the process of converting them to SCCP for our CUCM 7.
Unfortunately some of these phones are password protected and I can't unlock them.
I really want to factory default them first.
The procedure of pressing and holding # button until the factory reset prompt appears doesn't work on these phones.
It just proceeds to boot.
The firmware on these phones is:
POS-06-3-00
PC030301
PS03AT38
Is there some way for to default these phones?
Yury
virverma Tue, 10/06/2009 - 09:20
Try the password cisco
I have loaded SIP firmware on 7960 and they get locked but using the above password, i unlock them.
phonetech Tue, 10/06/2009 - 09:32
I am past that point. cisco is a default password and whoever managed these phones changed that.
virverma Tue, 10/06/2009 - 10:51
See your objective is to convert them to SCCP,
I had this kind of issue with CM4,
what i did, I configured the phones to get ip from CM scope,
once i am able to see it in CM4 phones section with correct IP, I manually put the OS name there.
i am sure we can do it in CM7 as well, only difference is CM7 can register SIP phones
phonetech Tue, 10/06/2009 - 11:13
The problem is that I need to get in the phone to change networking config to
point the phone to CUCM or to TFTP server.
phonetech Wed, 10/07/2009 - 03:21
In order to get to this sequence you have to hold # during the boot.
See my post at the beginning of the thread.
Paolo Bevilacqua Wed, 10/07/2009 - 03:36
Sorry I had not read that.
Your only choice is wireshark to find find to which IP address wabt to download the configuration file, set up a TFPT server at that address and put the file there with the new SCCP load.
phonetech Thu, 10/08/2009 - 10:50
Well, it looks like the end the road for this phone.
I've tried to telnet into it and used the serial port, but they all ask for a password and default password cisco doesn't work there either.
Paolo Bevilacqua Thu, 10/08/2009 - 10:52
Telnet is not useful even if you had the passwords.
All and any phone can be recovered with the method above, but it require some skills and experience.
