IP Pools on ACS 5.0
Answered Question
Oct 6th, 2009
I am in the process of migrating from ACS 3.3 for Windows to ACS 5.0. Does the ACS 5.0 support IP pols on the box itself? I can't seem to find the option on the box.
Correct Answer by Jagdeep Gambhir about 7 years 7 months ago
ACS 5.0 and later will not support IP pools for IP address assignment.
You can still assign individual IP addresses using the RADIUS attribute
8, Framed-IP-Address and specific rules. You can have the IP addresses defined in an AD attribute and then use it for assigning the RADIUS attribute.
We recommend instead, to use DHCP for all IP address assignments. DHCP scales much better than what ACS could support.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Tue, 10/06/2009 - 09:56
  • Red, 2250 points or more
~JG
randyclark Tue, 10/06/2009 - 10:02
That's what I thought but couldn't seem to find it in the docs.
