CCENT Test Question:
Oct 6th, 2009
To whom it may concern,
I took the CCENT recently and one question was what command to use to see what is connected to your router w/o using any of the "show" commands. This has been stuck on me because I still can't locate the answer. All help appreciated!!
jimmysands73_2 Tue, 10/06/2009 - 19:00
  • Silver, 250 points or more
Deacons,
Only thing remotely I can imagine is something like :
more running-config
deacons323 Wed, 10/07/2009 - 06:06
Hi Jimmy,
I will check that out... It's been killing me to find the answer for this.
Thx again
viyuan700 Wed, 10/07/2009 - 06:55
"see what is connected to your router w/o using any of the "show" commands"
Does it mean what other switches or routers are connecetd to this router.
Or
What interfaces this router.
If it means what interfaces this router have then at the startup it shows what interfaces the router have, rebooting it will show without using show command.
deacons323 Wed, 10/07/2009 - 07:06
My apologies..... If I recall correctly I believe it asked what switches are connected to it.
