CM 6.1 and High Traffic Try Again Later
robertlwalk
Greetings,
We are running a CM 6.1.2.1000-13 BE system and just started seeing the "High Traffic Try Again Later" message appear on the display of a few phones. In one case the call was dropped as well. Checked all the logs on CM as well as voice gateways and don't see any errors. I found a post referring to this back on version 3.X and a memory leak on 4.1 but nothing newer.
Has anyone seen this or have any insight?
Cheers,
Rob
gogasca
Level 10
Level 10
Hi Rob,
High traffic is normally because of System resources.
When you check CUCM SDI/SDL traces look for High Traffic and timestamps specially we need to see SDL Queues, it may be CPU,Memory.I/O or HW failure we dont known.
This may require more investigation
If you have details SDI, SDL traces and perfom logs for last re-ocurrance please open a TAC case with us so we can track this problem.
We will open a TAC case. Thank you for your response.
Rob
