WiSM Module powered off
Oct 6th, 2009
I am using a Fan Module 1 on a 6509 chassis and it is giving me an error of insufficient cooling, is there a way around it or do I need Fan Blade 2??
Also how can turn on the WiSM Module?
Lucien Avramov Tue, 10/06/2009 - 12:36
  • Red, 2250 points or more
You can issue an hw-module boot or hw-module reset
If you need additionnal get it, you should not try to work around such need.
fmirza007 Tue, 10/06/2009 - 12:40
I tried that command but this is what I am getting;
Router#hw-module module 6 reset
Proceed with reload of module?[confirm]
% module 6 is operationally off (insuff cooling capacity)
any ideas?
da.beaver Wed, 10/07/2009 - 08:20
What version of Code are you running? Also what SUP module is in the chassis?
Lucien Avramov Wed, 10/07/2009 - 08:40
you need to add a fan in your cat6k chassis in the fan slot.
Leo Laohoo Tue, 10/06/2009 - 14:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Did you just newly-insert the WiSM? By default, power to the module is turned off until enabled by using the command
"power enable module ".
Hope this helps.
fmirza007 Wed, 10/07/2009 - 10:02
I tried that command and nothing happened. I am thinking I do need fan blade 2 to get this going...
on the side not what is the command to combine the power supply output instead of the redundant mode..?
Leo Laohoo Wed, 10/07/2009 - 14:16
  • Hall of Fame,
    2017 LAN, Wireless
If you look at your chassis now, do you see a green status lamp of the WiSM? If not, then it's not getting power. What is the result if you do a "show module"?
sh power status power-supply <1 or 2>
Trending Topics - Security & Network
