vpn led active
Oct 6th, 2009
i establishing a vpn tunnel betwwen 1 asa 5510 and 5 routers 1841.I xas able to establish the tunnel for the first router 1841 however the second show the vpn led of the asa green packets are encrypted but none decrypted and i can not ping from on side to the other here is the output of sh ipsec sa
help
pompeychimes Tue, 10/06/2009 - 19:58
  • Bronze, 100 points or more
What IP are you pinging from and to? Do these IP's reside on the end point devices or on devices behind the end points.
kolawole1 Tue, 10/06/2009 - 22:41
they reside on both the endpoints and the local subnet
frattonfaithful Tue, 10/06/2009 - 22:51
So to be clear you are sourcing the ping from the 130.223.122.0/24 network to the 128.223.125.0/24 network and vice versa.
Please provide "sh crypto ipsec sa detail" output from both sides.
kolawole1 Wed, 10/07/2009 - 04:04
Here is yhr output I am able to ping from the asa console to the router's 130.223.122.0/24 SUBNET but the not from the asa 128.223.125.0/24 lan interface
From the rtr (both console and inside) i am able to ping the asa outside interface where crypto map is applied
