Change Administrator Password on 2811 Router
Answered Question
Oct 6th, 2009
We have fired the company who supported our 2811 routers and I would like to know how to change the Administrator password so we can prevent their access while we are looking for a replacement company
Correct Answer by Reza Sharifi about 7 years 9 months ago
David,
Make sure the new one is working fine before you delete the old one.
the command to delete the old one is:
config t
no username admin
Reza
Correct Answer by Collin Clark about 7 years 9 months ago
You can reduce your risk by creating another account before deleting the admin account.
username administrator secret MyPaSsWoRd
Then create another telnet session (leave the original one open) and authenticate with the username administrator. If successful you can delete admin and re-create or just use the administrator account.
Overall Rating: 5 (2 ratings)
Brent Rockburn Tue, 10/06/2009 - 12:48
How are you gaining access? SSH? Telnet? is tacacs or radius being used?
dscottsos Tue, 10/06/2009 - 13:03
Telnet using CLI commands and I login as user admin
Collin Clark Tue, 10/06/2009 - 12:49
  • Purple, 4500 points or more
Assuming you're using local authentication;
no username administrator
To create a new one-
username administrator secrete mYPaSsWoRd
dscottsos Tue, 10/06/2009 - 13:05
I currently access the 2811 using a telnet connection and CLI commands and login as Admin which has all rights and then the system uses the same password for login and enable functions.
Collin Clark Tue, 10/06/2009 - 13:06
no username admin
username admin secrete mYPaSsWoRd
dscottsos Tue, 10/06/2009 - 13:20
Thanks but I am not sure I understand, there is a current username admin that I use to login to the router. You are suggesting creating a new one. Is that to overwrite/replace the current user? Maybe I should wait until I find a new company and run the risk.
Collin Clark Tue, 10/06/2009 - 13:24
First you delete the username admin. Next your creating a new admin account so you can login with that account and the new password.
Correct Answer
Collin Clark Tue, 10/06/2009 - 13:28
dscottsos Tue, 10/06/2009 - 13:33
Thanks, I have the new username and password, what is the command to delete the old Admin username.
Correct Answer
Reza Sharifi Tue, 10/06/2009 - 13:43
  • Cisco Designated VIP,
    2017 LAN
David,
config t
no username admin
Reza
