7975G IP Phone - PC Port Negotiation
Oct 6th, 2009
Replaced a 525G phone with a 7975G phone, so the PC port is now 1000/100/10.  There is a small switch connected to the PC port and now will not connect.  Seems that Auto negotiate is not working correctly on either the phone or the switch.  If I directly connect to a PC, the link is established.
I see there is a selection in the Network Configuration on the phone for PC Port and it is set to Auto Negotiation, but I do not have the option to change it.  Is there a way to change this from Auto, to a static selection (ex: 100 Full)
Steven Smith Tue, 10/06/2009 - 13:04
You might need a crossover cable if you literally have a switch behind the phone.
But, you can set the speed manually.
Settings -> Network Configuration -> Option 9.
Be sure to press **# to unlock the phone.
brandon.kallas Tue, 10/06/2009 - 13:08
Yep, that did it.   I guess this switch does not auto-sense device to device.
Just so you know...  I did go to that option on the phone and unlocked the settings, but there is still no option to change that setting.
Steven Smith Tue, 10/06/2009 - 13:15
Is the edit button not available there on that screen?  I am looking at a 7975 running beta code on a test CallManager, but I am pretty sure the option should be available for you to change.
On the 7945 I have on my CME, it is also available for edit.
Steven DiStefano Tue, 10/06/2009 - 13:51
brandon,
Hi.
Even after you press * * #   ???
I just tried on my 7975 and the edit button appeared.
steve
brandon.kallas Tue, 10/06/2009 - 14:59
Correct.   I press **# and the lock opens, but there is only the exit button.   Is there something that needs to be placed in the telephony-service section to allow this function to work??
Here is the telephony-service section of the config:
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
authentication credential
load 7914 S00105000300
load 7915-12 B015-1-0-3
load 7915-24 B015-1-0-3
load 7916-12 B016-1-0-3
load 7916-24 B016-1-0-3
load 7906 SCCP11.8-4-2S
load 7911 SCCP11.8-4-2S
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7931 SCCP31.8-4-2S
load 7936 cmterm_7936.3-3-16-0
load 7937 apps37sccp.1-3-2-0
load 7960-7940 P00308001000
load 7941 SCCP41.8-4-2S
load 7941GE SCCP41.8-4-2S
load 7942 SCCP42.8-4-2S
load 7945 SCCP45.8-4-2S
load 7961 SCCP41.8-4-2S
load 7961GE SCCP41.8-4-2S
load 7962 SCCP42.8-4-2S
load 7965 SCCP45.8-4-2S
load 7970 SCCP70.8-4-2S
load 7971 SCCP70.8-4-2S
load 7975 SCCP75.8-4-2S
load 521G-524G cp524g-8-1-16b
load 525G spa525g-7-1-9
max-ephones 40
max-dn 160
ip source-address 10.1.1.1 port 2000
auto assign 10 to 43
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 30
system message
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 6
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name administrator secret 5 $1$y4fO$8yUuRhwYVTAzKvT1rTI4G0
web admin customer name admin password
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
Marcos Hernandez Tue, 10/06/2009 - 13:20
A switch behind the phone is never a good idea. Our newer ESW switch, for example, implements a security smart ports policy that limits the number of MAC addresses that can be learned by a particular switch port when the IP+Desktop profile is used.
Marcos
