reports for extension mobility
Oct 6th, 2009
Is there any report on CUCM 6.x shows when the user login and logout using extension mobility feature during period of time for example one month.
Jaime Valencia Tue, 10/06/2009 - 17:38
  • Cisco Employee,
  • Hall of Fame,
    2011
No, you would need to enable EM traces and then parse thru them in order to find out login/logout events to get the info
java
if this helps, please rate
There is a solution for this. it is called ALM PRO+.
ALM PRO+ allows companies to view ExtensionMobility usage and is able to run detailed reports for usage and management purposes.
  • Centralised administration for all sites/locations using ALM PRO
  • License management and control
  • Advanced reporting on EM usage
  • Extended management reporting options
  • Calculating work space usage
  • Manage user and group profiles
  • Web-based administration
Drop me a PM for more information
