Backup failure on UC520
Oct 6th, 2009
Hello
Im faceing a strange problem. Suddenly i can't make backups of my UC520W. It's running CUE Version 7.0.3 and IOS 12.4(20)T2.
Have tried in CCA (2.1)and in CUE, but none of them worked.
When i use the CUE to backup, i get the following error:
Configuration: Failure Script execution failed: /bin/run_curlbackuprestore.sh: line 29: /usr/bin/BR_WeexDataBackup.sh: No such file or directory
Data: Success
HistoricalData: Success
TimeCardView: Success
When i use CCA i'm stuck at 89%...
Any ideas?
Thanks in advance
Henrik Taaning
Steven Smith Tue, 10/06/2009 - 14:37
Do you use phone connect on your system?  Please let me know and in the mean time, I will try backing up my system to see if I get the same error.  This one might result in a TAC case.
henriktaaning Tue, 10/06/2009 - 14:45
No, i guess it's a standard setup..
Tried going back to Factory Default, and the used the Telephony Setup Wizard in CCA. But with the same result...
Even tried a Factory Default and only initialized the Voice system (Number og digits and voicemail) again with the same result.
Strange....
Steven Smith Tue, 10/06/2009 - 15:17
I couldn't get this to fail.  Are you doing this via the web or the console?  I would open up a TAC case for this issue.
henriktaaning Fri, 10/09/2009 - 03:35
Solved!
Turns out that the CUE had some sort of errors, causing the backup failure.
When I tried upgrading the CUE from CCA, it starts the backup, and of course fails, again.
So I found this guide to upgrade CUE in CLI using Boot Helper, without making a backup first:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_0/installation/guide/upg3boot.html#wp1134168
Everythings works fine now...
Cheers, and have a nice weekend
Henrik
