How to have 2 or 3 sec delay for 2 sequence of digits string for dialed no.
Oct 6th, 2009
Hi All,
I got a discount rate telephone provider that i need to used.
to used it i must first dial 1800123123 no, and wait for 2 or 3 sec before dial my destination no.
I have try to prepend the Prefix Digits (Outgoing Calls) dialed out with 1800123123 and fail to make a successful call.
How do i configure this in call manager?
Jaime Valencia Tue, 10/06/2009 - 17:40
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM cannot insert a pause in the dialed string.
You could possibly do this in H323 GW by using the , which stands to a 1 second delay
Or Unity which also uses , as 1 second delay
java
if this helps, please rate
lukman.mdisa Tue, 10/06/2009 - 20:53
Hi javalenc,
the current PSTN gateway are using MGCP to communicate with CUCM.
can i re-add the gateway to use H323?
Can you refer me to any doc about this.
Thanks.
