spa400 crash issue
Oct 6th, 2009
I do not have any additional debug information other than what is below (don't keep syslog logging events at all times, and enabling when this situation occurs involves a reboot which clears it).
Is there a bug already known for this kind of issue?  Basically, although lines are connected, all lines show off-hook with battery level 0.  No incoming calls are answered.  Outbound calls for most steering digits seem to route around this situation.   Any suggestions?  Obviously this is a serious issue for us (and has happened more than once in the last year) since this requires a reboot of the gateway to bring it back.  Please help.  Thanks -Don
        Firmware Version: 1.1.2.2 Build Date: 16:28:51 Aug 6 2008 MAC Address: 00:18:39:23:AA:7E Current Time: 12:02:44 Sep 27 2009 System Up Time: 4 days and 1:57:29   Internet Connection      IP Address: 10.1.2.41 IP Subnet Mask: 255.255.255.0 Gateway IP Address: 10.1.2.1 Primary DNS: 10.1.2.1 Secondary DNS:  SPA400 Status      USB status: Mount Voice mail status: OK USB capacity status: Used 1806KB, remaining 123866KB SIP registration status: Registered FXO Line status       Hook Status  Line 1 status: Off-Hook Line 2 status: Off-Hook Line 3 status: Off-Hook Line 4 status: Off-Hook    Battery Level  Line 1: 0 V Line 2: 0 V Line 3: 0 V Line 4: 0 V ===========
after reboot below:
Firmware Version: 1.1.2.2 Build Date: 16:28:51 Aug 6 2008 MAC Address: 00:18:39:23:AA:7E Current Time: 12:38:12 Sep 27 2009 System Up Time: 0 days and 0:07:52   Internet Connection      IP Address: 10.1.2.41 IP Subnet Mask: 255.255.255.0 Gateway IP Address: 10.1.2.1 Primary DNS: 10.1.2.1 Secondary DNS:  SPA400 Status      USB status: Mount Voice mail status: OK USB capacity status: Used 1808KB, remaining 123864KB SIP registration status: Registered FXO Line status       Hook Status  Line 1 status: On-Hook Line 2 status: On-Hook Line 3 status: On-Hook Line 4 status: On-Hook    Battery Level  Line 1: 53 V Line 2: -50 V Line 3: 0 V Line 4: 51 V
Alberto Montilla Thu, 10/08/2009 - 07:15
Hi Don;
What firmware is used on the SPA400? I suggest you upgrade to the latest if not done yet.
Alberto
donwbpa3donwbpa3 Thu, 10/08/2009 - 19:38
I pasted the info into the post.  It is version 1.1.2.2 which shows as the latest on the web site.  Is there another version that fixes this kind of issue in development or is there a file that would be created on the spa400 when this kind of this occurs that I could grab and provide to help troubleshoot? -Don
Alberto Montilla Tue, 10/20/2009 - 09:41
Hi Don;
Sorry for the late reply.
Best thing to see what the issue is about is to collect the syslog info provided by the SPA400. Not sure it would help in this case but may be.
Alberto
