IPSec on cisco router 2801
Oct 6th, 2009
Dear sir,
I want to move IPsec configurations from 857 DSL rouer to 2801 LL router, I tried to put "crypto" comand on cisco 2801 but it's not supported by current IOS on router, Shall I need to upgrda IOS? which version should I use?
Thanks and regards
Jon Marshall Wed, 10/07/2009 - 04:16
Islam
It's not the version but the Feature set you need to change. You need either
1) Advanced Security
2) Advanced IP Services
3) Advanced Enterprise Services
Feature Navigator is the tool to use for this because you also need to check that if you upgrade to any of the above feature sets you still have all the features you are currently using -
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Jon
islam_cisco Fri, 10/09/2009 - 23:55
Thank you Jon
I tried to search using this tool, however I got confused with all this types and features, kindly can you help me more and advise which IOS image exactly do I need, I have cisco 2811 and want "crypto" command to be enabled, simply that's it
Islam
islam_cisco Sat, 10/10/2009 - 02:33
I tried the following IOS images:
c2800nm-ipbase-mz.124-15.T9.bin
c2801-adventerprisek9-mz.124-25.bin
However, I still unable to write "Crypro"
Comand what is the problem ?!
Does it beacuse my router is 2811 and this is belong to 2800 routers ?
jiaowenbin Sat, 10/10/2009 - 22:33
I have meet this situation when the MPE module was installed on router 2811,
I can type crypto command , but there is no ipsec&isakmp parameters,just like this :
Router(config)#crypto ?
engine Enter a crypto engine configurable men
pki Public Key components
and of course my feature set is security
maybe this is helpful for you
