Cisco WAP4410N - not configurable as Wireless Client with WRT610N?
Oct 7th, 2009
Hi!
On several workstations I use multiple network to
1 - access Internet and share Printers
2 - communicate within the local area
The second WLAN I need for several NDAS devices.
Due to their own LPX-Protocol these NDAS devices don't work properly with MAC address cloning. In combination with several access points or clients from other manufacturers Wireless N transmission does not work.
So in WLAN 2 I use the Cisco Linksys WRT 610N Router with 2.4 Ghz WLAN.
I intended to use the Cisco WAP4410N in Client Mode to connect a workstation with this router and set up NDAS connection.
Other workstations will directly connect to the router via Cisco Linksys WUSB-600N.
The connection from WUSB-600N to WRT610N works perfectly.
My problem is:
The WAP4410N does not connect to a wireless Network in Client Mode.
(It is not a problem of Channel configuration, Security or Signal strength - because if I connect my workstation via WUSB-600 this works instantly.)
If setup as an access Point it will start up sending competing to my router.
In Network Status it shows no received packages.
In Wireless Client/Repeater Mode there is no connection either.
My question is:
Is the WAP4410N not designed to be used as a Wireless Client?
An if it was - how is it to be set up as one?
ando_user
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
