LMS 3.2 - Autologout after xxMin of idle time
Oct 7th, 2009
Hi there,
are there any options to LMS/Portal automatically logout a user having an idle session of xx mins?
Thanks for any feedback
Lothar
Joe Clarke Wed, 10/07/2009 - 07:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The Tomcat session will automatically expire are two hours of idle time. This is not configurable.
lo.mueller Wed, 10/07/2009 - 23:04
Would it be possible to edit the corresponding tomcat-config file?
Or does editing affect other CW-Processes
[Tomcat_home]/conf/web.xml:
120
Thanks for your feedback
Lothar
Joe Clarke Thu, 10/08/2009 - 08:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This does control the session logout time, but modifying this file is not supported. If you run into problems, you will have to revert before TAC can help you.
