AP1131G fail to bring ethernet link up
My AP1131Gs was automomous and I was upgrade to LAPs.After few days several APs was fail due to ethernet cable(one of pins is broken).I can not bring it up
connect to WLC anymore.Then I try to recover back to automomous by press Mode switch on APs through TFTP.It is back to IOS image but I found the APs FE0 and BVI1 always down.I try to change configure FE0 to speed 100/duplex full and it is up( link up/ping OK). But I can not upgrade this APs as before.
I was told this is AP bug?Is is true?
Someone could give me further info about this?
Leo Laohoo Wed, 10/07/2009 - 14:35
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Did you try to use the Upgrade Tool to convert from autonomous to LWAP image?
mthurman Thu, 10/08/2009 - 08:09
I tried this once and it worked. If IOS is running on AP login and do:
archive download-sw /overwrite tftp:///
Example:
archive download-sw /overwrite tftp://10.4.1.20/C:\TFTP-Root/c1250-rcvk9w8-tar.124-10b.JA3.tar
Good luck
