MLS configuration for routing
Oct 7th, 2009
I'll set the scene...we are getting a Layer 2 ethernet presented LAN extension, that we wish to route to our firewall via a C3560G switch, using a routed port (See attachment for diagram).
Can you confirm this is possible and also how this would be configured?
Brian
Jon Marshall Wed, 10/07/2009 - 03:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Brian
Yes it's possible. You need to configure the port on the 3560 that the LAN extension connects to as -
int gi0/1
no switchport
ip address 192.168.5.1 255.255.255.252
obviously the other end of the LAN extension wherever that is would be configured with the ip address 192.168.5.2/30.
Jon
Jon Marshall Wed, 10/07/2009 - 04:05
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Brian
Yes you would need to enable "ip routing" on the switch.
Your other option is simply to have the 3560 as a L2 switch only and run it to the firewall.
Jon
glen.grant Wed, 10/07/2009 - 04:33
  • Purple, 4500 points or more
Yes routing would be turned on .
johnstone_cisco Wed, 10/07/2009 - 06:57
I plan to put static routes on the switch
ip route 0.0.0.0 0.0.0.0 'my Firewall int address'
ip route '3rd Party lan' 255.255.255.0 'routed switch port'
I assume these entries will only effect the traffic via the routed port, the remaining layer 2 ports on the switch will continue to act as normal?
Brian
Jon Marshall Wed, 10/07/2009 - 07:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Brian
would be better to use
ip route '3rd Party lan' 255.255.255.0 ie. 192.168.5.2 in the example i gave.
"I assume these entries will only effect the traffic via the routed port, the remaining layer 2 ports on the switch will continue to act as normal?"
the routes will affect any traffic that is routed on your 3560 especially the default route. Looking at your setup this should be fine.
Jon
