Codec Restriction Help Please
Oct 7th, 2009
Kindly assist with this pertinent problem.
How do i filter the number of supported codecs on my sip-outbound trunk? (i would like to enable support for only the following codecs (t38,g729ab,pcmu,pcma,gsm-hr). Due to the large number of supported codecs by default on the media gateway (as5400-xm) packets get fragmented as the mtu size of 1500 is exceeded and as such calls fail because the SIP invite never gets to the other end. thanks
paolo bevilacqua Wed, 10/07/2009 - 03:56
  • Hall of Fame,
    Founding Member
Configure a codec list and apply to DP.
As explained in documentation and training.
snzeadibe Wed, 10/07/2009 - 04:52
Thanks for your response/help p.bevilacqua.
I have checked the documentation. however can you let me know exactly which of these would solve the problem?
By Editing the Trunk Group Property
1. Traffic -> Trunk Groups -> TrunkGrp Property -> GWDefaultCodecString
OR
By Editing the Result Type for DP
2. Number Analysis -> Result -> Codec -> CodecString
thanks again
