H323 advice
iptuser55
Level 6
Level 6
It may be a stupid question but my brain is dead at the moment
I have GW 1 registered to a CCM using MGCP which in turn connects to GW2 using a E1 WIC on each GW with RJ45 cable between them. GW2 then provides VOIP dial-peer pointing to other GW`s in our Clound - this second GW is not registered to CCM.
Question - I want to do away with the first MGCP GW and the physical RJ45 conenction and connect directly to the second GW wihtout any physical connection ,almost like Gatekeepe,Trunk connection - can I configure the GW2 as a H323 device on CCM and use VOP dial-peers to point back to CCM ?
paolo bevilacqua
paolo bevilacqua
Yes, absolutely.
Thanks for the quick answer
CUCM DN`s 1...
Do I just add a H323 GW in CCUM and on the GW do I
create Dial-peer voice xxxx voip
Destination-Pattern 1...
Session TargetIPV4:X.X.X.X- CUCM IP address
Outbound to Clound
Dial-peer voice YYYY VOIP
Destinatio-Patterns 2...
session target ipv4:- next GW
Is this ok ?
