Changing Username/Password Prompts on AnyConnect Client
jickfoo
Is there any way to change the language on the AnyConnect client?
The client prompts for
Username
Passcode
Second Password
I want to change what these say to
Username
Password
RSA Passcode
Any help would be greatly appreciated. I can find how to change responses from the switches but not the prompts.
Justin
7 Replies 7
Collin Clark
I've never done it, so I'm not sure it can be done, but here's the guide on customization.
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect23/administration/23admin5.html
Worse case scenario, you can build your own client and use the AnyConnect API.'
thanks for the reply.. unfortunately there's nothing in the guide about changing the prompt text. I also wouldnt be comfortable in creating our own client.
I wish it had the RSA prompt as well. We have a Juniper device that's worse. It states Password for domain auth and Passcode for RSA. Lot's of helpdesk calls after initial deployment.
Hi Collin,
I use Juniper as well. You can change those prompts by implementing a custom sign in page.
kirkulees007
I know this is old, but we are looking for the exact same solution.  Is it possible to change the password prompts?
jmcdonough
You can modify the prompts by editing the en-us file.
  • Go to: Configurations\Remote Access VPN\Network (client) Access\Anyconnect Customization/Localization\GUI Text and Messages
Click edit to edit the file.  Search for the existing text prompt you want to edit.
Here’s my example.
I wanted to edit “Passcode”.  Running a search of passcode brought me here.
                #: 722e3d35ad39848fd16c341898f273cf
                msgid "Passcode:"
                msgstr ""
Edit the msgstr field to what you want displayed, like so.
                msgid "Passcode:"
                msgstr "RSA Pin"
Save the file and test.
I also changed Second Password.
                #: c81279053dfc5079c9afc2ccc070761b
                msgid "Second Password:"
                msgstr "Network Password"
I previously displayed
                Username:
                Passcode:
                Second Password
Now it displays
                Username:
                RSA Pin
                Network Password
I recently spoke to TAC and an engineer told me you can’t change the order to have Network Password above RSA Pin.  He said you can only customize the order on the clientless vpn.
Here’s a link he gave me for what can be changed.
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect31/administration/guide/anyconnectadmin31/ac12customize.html#pgfId-1151587
Do you know if there is any update on this by now?
