Cisco ISR (sh conn ???)
Oct 7th, 2009
hi,
I'm migrating all my cisco PIX used as VPN peers by Cisco ISR routers.
I would like to refind a bit same information.
does it exist something like "sh conn" on routers ? to see all connections : udp, tcp, icmp.. ?
if you know how to get that, I'm interested.
thanks
regards
Nicolas
Collin Clark Wed, 10/07/2009 - 05:37
  • Purple, 4500 points or more
Nicolas,
show ip nat translations
Below are sub-options as well.
global Display entries in Global/Dest Table - NVI
icmp Show ICMP entries
pptp Show PPTP entries
tcp Show TCP entries
udp Show UDP entries
verbose Show extra information
vrf Display entries of VRF instance
| Output modifiers
nvanhaute Wed, 10/07/2009 - 05:41
hi,
thanks, but like I said before I use ISR only as VPN peers, so there is none nat
Nicolas
Collin Clark Wed, 10/07/2009 - 05:52
Sorry about that. Try enabling IP Accounting. That should give you the connections you're looking for. I'm not 100% sure it will give you the port numbers though.
nvanhaute Wed, 10/07/2009 - 06:01
thanks that works well on my tunnel interfaces
you are right, there is no port indication :-( (if you have an idea)
but it's not real time traffic, right ? it keeps history :-(
it's better than nothing, but I try to find better
thx
Nicolas
