Not able to change the ip address on ACS.
Oct 7th, 2009
Hi Experts,
I am trying to configure/change the IP address of the ACS appliance through console port but the problem is that it is not allowing me to do when it is up and running hence i restarted it and went to bios diagnostic msgs after ACS boots up my console is not responding to anything. Kindly let me know do i need to follow any other procedure or is it issue with the hardware.
My ACS version 4.2.0.124..
Thanks in advance.
Neha
Overall Rating: 4 (2 ratings)
Jagdeep Gambhir Wed, 10/07/2009 - 05:45
  • Red, 2250 points or more
Neha,
You can try reloading it again and see if it give console access. Is it ACS1113? If it is then I would suggest to open a TAC case as there are some known boot up issues in 1113. If required, TAC will replace it with the new one.
~JG
Do rate helpful posts
nehakulsum Wed, 10/07/2009 - 06:14
Hi Jagdish,
Yes it is Cisco ACS Appliance 1113.
Neha
Jagdeep Gambhir Wed, 10/07/2009 - 06:20
HI Neha,
Please try to reload it and see if you get a console access. If we are not able to get a console access via serial then you can try two options,
1) Open a TAC case and get it replaced (Recommended)
2) Try to reimage it as suggested by JK.
~JG
Jatin Katyal Wed, 10/07/2009 - 05:49
  • Cisco Employee,
Hi Neha,
This is only right way to change the ACS SE ip address.
Did you use the "Set ip" Command from the console connection. If not then please use this connection from the serial/console connection
set ip
Reconfiguring the Solution Engine IP Address
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/solution_engine/admap.html#wp1109621
If it's not booting/responding then you have to reimage the solution engine with 4.2 recovery CD.
JK
Plz rate helpful posts.
nehakulsum Wed, 10/07/2009 - 06:56
The appliance is not accessible via the console port. Console port is not responding so Do you recommend to re-image? As I am able to access the ACS via web intrfce and it is processing the request. Only thing is it does not repond on the console port - no prmpt or cmds to type it over there.
I rebooted the appliance , the device boots ups properly but does not display anything on the console .
So will re-imaging the device will solve this issue or its an hardware issue?
Thanks a lot for your help.
Neha
ansalaza Wed, 10/07/2009 - 06:31
  • Cisco Employee,
To change the IP address with "set ip", please make sure that the Server is connect to the Network using the bottom NIC.
For the Console...leave it connected for a while (try 10-15 minutes); you should get the logon prompt on the Terminal using these settings:
•Baud = 115200
•Databits = 8
•Parity = N
•Stops = 1
•Flow control = None
Jatin Katyal Wed, 10/07/2009 - 07:00
  • Cisco Employee,
Hi Neha,
If you can access it via HTTP then I think you look the hyperterminal settings one more time. Most of the times we miss baud rate. Please ensure that we have
•Baud = 115200
If this is what you already have then reimage is the only option.
JK
Plz rate helpful post.
