Force IP phone login
Oct 7th, 2009
Running CUCM 7.02
7911, 7942 handsets
Wanted to secure some phones out of hours, was looking at doing some Time of Day Routing but wanted to users to be able to login to override the block.
Does anyone know a way to force user login on phones before CSS becomes active.
Jaime Valencia Wed, 10/07/2009 - 06:36
You would need to look into 3rd party solutions to lock the phones (search NetPro and you'll find plenty of posts on the subject)
Or use EM
java
if this helps, please rate
