Oct 7th, 2009
We have a private WAN IP network (WAN: consisting with five different subnets each with their own IP (LAN)addressing space.
LAN 1=
LAN 2=
LAN 4=
LAN 5=
I need to be able connect LAN 5 to LAN 3 (VLAN) - and route all Internet traffic from LAN 3 (VLAN) to a gateway on LAN 5 - while at the same time restrict LAN 5 from connecting to any of the other LANs.
The biggest problem I can't get my arms around is all of the 10.x networks involved. We also employ EIRGP on each router.
iholdings Wed, 10/07/2009 - 07:20
Logic check: Will this work?
LAN 5 router:
interface GigabitEthernet0/0
description ***Connection to WAN***
ip address
ip flow ingress
ip flow egress
duplex auto
speed auto
interface GigabitEthernet0/1
description *** LAN port ***
ip address
duplex auto
speed auto
ON LAN 3 router:
ip dhcp pool JPI
interface GigabitEthernet0/1.14
description ** LAN 5 **
encapsulation dot1Q 14
ip address
ip access-group INETLAN5-ONLY in
ip policy route-map INETONLYLAN5
no snmp trap link-status
ip access-list extended INETLAN5-ONLY
permit udp any any eq bootpc
deny ip any
deny ip any
deny ip any
permit icmp any any
permit ip any any
ip access-list extended LAN5-INETONLY-NETS
deny ip
deny ip
deny ip
permit ip any
deny ip any any
route-map INETONLYLAN5 permit 10
match ip address LAN5-INETONLY-NETS
set ip next-hop
Leo Laohoo Wed, 10/07/2009 - 12:41
shutdown < --- Your LAN may NOT work.
iholdings Thu, 10/08/2009 - 03:59
Yes - I had that down prior to shipping the router to LAN5. The router is now up with LAN up, but neither LAN on both ends can see the other. I can ping hosts on LAN3 from the LAN5 router, but hosts behind each can't get to the other side.
iholdings Thu, 10/08/2009 - 04:02
Correction - from the router on LAN5 I can ping hosts behind LAN3 router - but I can only ping the LAN port on LAN5 router from the LAN3 router.
