2 out of 6 1131 AG AP are administrative down
Answered Question
Oct 7th, 2009
Our Wireless configuration is all installed serving our main campus connected to diferents switches. we have 6 AP in 3 building all interconnected and 2 of them always show up as connected but Administrative Down, so the 2 AP can be managened from the WLC but are not broadcasting the SSIDs or allowing any connection.
We also upgrade to the latest AIRONET OS (6.0) and reconfigured the WLC and all stayed exactly as before, 2 out of 6 AP are Admin Down.
Any help will be appreciate it.
Correct Answer by mthurman about 7 years 4 months ago
Please rate my answer and mark as solved. Thank you.
Overall Rating: 5 (1 ratings)
mthurman Thu, 10/08/2009 - 05:56
Go to configure AP's and check setting for Power over Ethernet Settings. Make sure Power Injector State is checked.
jimenez-raul Thu, 10/08/2009 - 06:03
Thanks, yes, re-registering the injectors solved the problem.
Apprecited
Correct Answer
mthurman Thu, 10/08/2009 - 06:06
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
