10-07-2009 07:14 AM - edited 03-15-2019 07:57 PM
Hi!
Today i've tried to configure background images for 7965 phone on UCM 6.1.4.1000-10.
I've uploaded images via WEB-GUI to /Desktops/320x212x16.
Then i've uploaded the List.xml into to the same directory with the following content:
<CiscoIPPhoneImageList>
<ImageItem Image="TFTP:Desktops/320x212x16/logo_vertikal_ico.png"
URL="TFTP:Desktops/320x212x16/logo_vertikal.png"/>
<ImageItem Image="TFTP:Desktops/320x212x16/logo_horizontal_ico.png"
URL="TFTP:Desktops/320x212x16/logo_horizontal.png"/>
</CiscoIPPhoneImageList>
I've restarted and stopped/started TFTP already. It is a 1:1 Redundancy - therefore i've restartet both TFTP servers but no result. The phones still don't list up the images. I've also reset the phone but same result.
On the WEB-GUI the files get listed up but on the CLI don't:
admin:file list tftp /Desktops/
<dir> 320x212x16
dir count = 1, file count = 0
admin:
admin:file list tftp /Desktops/320x212x16
no such file or directory can be found
admin:
I hope someone can give me some feedback for further troubleshooting.
Thanks in advance!
BR,
Christoph H.
10-07-2009 07:51 AM
Hi Christoph,
You will want to ensure that the naming convention on the files are exact. I came across a issue where my PNG files were actually .PNG and I had .png in the List.xml which was the issue.
You will also want to ensure the List.xml is using a capital L.
You will also want to ensure that the files are the recommended size.
I would try reuploading the files as well then restart the TFTP service.
also if a background image just does not want to show up, it's a good idea to browse to the phone web site and check the Console Log for failures
7945 / 7965
Full size image-320 pixels (width) X 212 pixels (height).
Thumbnail image-80 pixels (width) X 53 pixels (height).
Directory "/Desktops/320x212x16"
Justin
10-07-2009 10:58 PM
Hi!
Thanks for your fast response.
OK, i've checked the following things:
name convention of png files - OK
List.xml with capital L - OK
Already tried to reupload files & restart - no new result
Phone web site logfiles - at the moment not possible because of remote access restrictions :/ Same issue with RTMT - no data collection possible via remote access.
I'll try it on a testserver (Release 7.1.3) - do you think this will still be comparable?
BR,
Christoph
10-08-2009 07:23 PM
Hi chris,
my List.xml looks like for 7945/65
URL="TFTP:Desktops/320x212x12/BIG.png"/>
Desktops/320x212x12:
List.xml
Pls try this and rate:
10-13-2009 10:15 AM
it's a good idea to browse to the phone web site and check the Console Log for failures, you will see what's the phone is calling for from here
Justin
10-29-2009 06:37 AM
Hi all!
Thanks for your support.
I've could check the phone console logs as well: Phones tried to load files from Subscriber but couldn't find them
The strange thing was this:
Files were viewable via OS Platform GUI TFTP Management but not via SSH (directory not found).
Solution:
I just removed all files and re-added them via Web-Gui and restarted TFTP - didn't work.
I've restarted the Server - problem solved!
Could it be that another service is necessary on UCM 7 Release or was it by change that it works after the restart?
BR,
Christoph H.
