wireless doubts
Oct 7th, 2009
Dear Folks,
I have couple of questions, which I need your expert opinion :)
1. I have an RFP which mentions that client requires access points with external antenna's which requires 802.11g radio, capability to add .11a radio and can upgrade to N in future. Which ap is this ? as far as i know , its 1250 series. is it right?
2. Which ap's do you recommend for classroom environment? These classrooms are basically residental apartments. do you recommend these ap's to be inside classroom's or corridor? I feel 1130/1100 series is enough for these types of rooms as this may avoid interfering , unlike external antenna type like 1240/1250 series.
Any advise ?
SIDdarth
Rob Huffman Wed, 10/07/2009 - 10:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi SIDdarth,
1. Yes, the 1250 series is the only AP that meets the RFP requirements.
2.An 1100 would be a good fit, probably the "new" 1140 series which supports "N". Without doing a site survey it's hard to say where best to mount the AP's. We usually mount them above the common wall between two classrooms to allow good coverage in both :)
Cheers!
Rob
ciscokid7181 Thu, 10/08/2009 - 09:46
Hello Mr.Rob,
Thanks for the query.
I would like to know for point 2.
lets say for eg:20 students of each classroom accomodates with a teacher, is it safe to have an AP 1140 to be installed in the corridor, so that this AP would be receive simultaneously 42 clients for this access point.
-SID
Rob Huffman Thu, 10/08/2009 - 10:15
  • Hall of Fame,
    Founding Member
Hey SID,
You are most welcome my friend :) 40 users per AP is a tad high. The recommended number (depending on application) is probably @ 20-25 max. I would prefer 1 AP per classroom to meet these requirements.
Cheers!
Rob
Leo Laohoo Thu, 10/08/2009 - 17:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
I'm in the midst of doing wireless stuff for the Education department (pre-school all the way up to high school and colleges).
First rule I was instructed is NEVER (ever!) underestimate the (accuracy) throwing arm of a 6 year old. For this reason we never allow the AP's to be exposed. It's always hidden or locked up.
We have been progressively installing and upgrading APs to the 1250s. We are waiting for the delivery of the 1140s so we can use the autonomous image.
aaron7181 Fri, 10/09/2009 - 05:46
Hello Leo,
What type of locks do you recommend to secure AP's ? I have seen normal chinese locks which is used to lock travel bags[gold color]. Is there any specific locks like kensignton type ?
Aaron
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
