Cisco Unity 4.x SA Access Denied
Oct 7th, 2009
I'm having issues logging back into the system administration page. My default subscriber template was set to put all subscribers in the "default administrator" COS, so I moved all subscribers to a new COS...including the example administrator. Please Help! How do I assign a subsriber back to the default administrator COS without being able to log in to the SA?
-Stephen Cantu
Christopher McAlpin Wed, 10/07/2009 - 09:30
Probably the easiest way to assign a subscriber to a COS with administrator rights would be to edit the a subscriber record in the UnityDB SQL database.
From SQL Enterprise Manager expand the UnityDb and find the Cos table.
Right click on the Cos table and choose Return all rows. This will open the table. In the CosObjectId column, copy the CosObjectId for the defaultadministrator COS and close the table.
Right click on the Subscriber table and choose Return all rows. Find the subscriber you wish to assign to the defaultadminstrator COS and in the CosObjectId column, paste in the CosObjectId you previously copied.
Close the table.
You should be good to go.
