LMS 3.2 forbidden
Oct 7th, 2009
Recently installed LMS 3.2 and now when I try to log in I get the following:
Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Any ideas? Permissions on server have not been modified.
Joe Clarke Wed, 10/07/2009 - 11:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the output of the command pdreg -l Apache and the NMSROOT/lib/class/path/md.properties and NMSROOT/MDC/etc/regdaemon.xml files.
rmetro Wed, 10/07/2009 - 11:21
C:\Windows\system32>pdreg -l Apache
Process = Apache
Path = d:\CSCOpx\MDC\Apache\bin\Apache.exe
Flags = -d d:\CSCOpx\MDC\Apache -D SSL
Startup = Started automatically at boot.
Dependencies = TomcatMonitor
HMM...do not see entry for the last two.
I even ran pdreg -l and went through all register daemons. Do they need registered?
Joe Clarke Wed, 10/07/2009 - 11:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The md.properties and regdaemon.xml are files on the file system. Post the files.
Cisco Support E... Tue, 06/18/2013 - 02:51
Hello I wonder if you were able to fix this issue? I am having the same problem.
Thanks in advance
