GET VPN over the public internet
Oct 7th, 2009
I've started reading about GET VPN. Most documents talk about how this solution is not recommended over the public internet. But is it possible? Would it be possible to use GET and NHRP somehow? Does any one have any experience with such a configuration?
Overall Rating: 5 (2 ratings)
tomek0001 Thu, 10/08/2009 - 13:15
Thank you. That is exactly what I was looking for. One question, the document say:
-GDOI based DMVPN spokes behind Network Address Translation (NAT) are NOT supported for spoke to hub or spoke to spoke tunnel. The support may be available in later GDOI_DMVPN phases.
Would you know if that's already supported?
thank you,
auraza Thu, 10/08/2009 - 13:40
AFAIK, it isn't yet. It would be best to lab it out and see if it works.
If you are unable to lab it, I can try it out.
PS. If you found my posts helpful, please rate them.
