How to change default password in AP521G?
Oct 7th, 2009
I´m trying to change the default password in autonomous AP521G, the CCA2.1 sent me errors when I tried to change, or create another user with Privilege 15.
hepartida Wed, 10/07/2009 - 13:37
Hello Glenn, It´s not a password recovery problem. I´m trying to change the default Cisco/Cisco username/password, but the Config Assistant doesn´t allowed.
I´m going to try with CCA 2.0 version instead 2.1.
Best Regards.
hepartida Thu, 10/08/2009 - 14:11
Now with CCA v2.0 I created a new user and delete default user/password.
Glenn Quesenberry Fri, 10/09/2009 - 09:30
Glad to hear you found a work-around.  I'll make sure the CCA production team is aware of this issue.
Best Regards,
