Bug CSCsv36782
Oct 7th, 2009
Hello
I have identified the listed bug in our CUCM 4.2(3)sr4a, the work around for the bug is to ignore the issue.
Does anyone know if there is a fix for this bug?
Overall Rating: 4 (1 ratings)
Jaime Valencia Wed, 10/07/2009 - 12:09
  • Cisco Employee,
  • Hall of Fame,
    2011
According to the bug notes it will be fixed in the next BARS version but there is no ETA, currently as you can see in the status is still opened but has been postponed. Right now there is no fix.
java
if this helps, please rate
