Upgrading 6509 Sup720 from 12.2.17 to 12.2.18
Answered Question
Oct 7th, 2009
Hi all,
I need to upgrade my IOS from s72033-pk9sv-mz.122-17d.SXB11a to the newest IOS with security fixes. From what I found s72033-advipservicesk9_wan-mz.122-18.SXF17 seems to be the way to go but I would like to be sure. Should I expect to loose some features from this upgrade?
Thanks!
Correct Answer by Edison Ortiz about 7 years 4 months ago
Yes
Overall Rating: 5 (1 ratings)
04_TCRMCQ Wed, 10/07/2009 - 12:47
Thanks a lot, so you confirm that in order to keep the same feature set from the old packaging (s72033-pk9sv-mz) to the new (s72033-advipservicesk9_wan-mz) that would be the way to go?
Jerry Ye Wed, 10/07/2009 - 13:01
I believe that is the closest feature sets by comparing the name
ADV IP W/MPLS/IPV6/SSH/3DES + BGP
s72033-pk9sv-mz.122-17d.SXB11a.bin
Release Date: 16/Apr/2006
Size: 41144.47 KB (42131936 bytes)
Minimum Memory: DRAM:512 MB Flash:64 MB
ADVANCED IP SERVICES SSH
s72033-advipservicesk9_wan-mz.122-18.SXF17.bin
Release Date: 30/Sep/2009
Size: 79043.54 KB (80940580 bytes)
Minimum Memory: DRAM:512 MB Flash:128 MB
You can compare the feature set with
