10-07-2009 01:15 PM - edited 03-10-2019 04:43 PM
I am using the CAS as an authenication server against AD for my wireless network. I have a WISM as my WLC and some of my users are getting a certifate error when I enable WPA. The error is coming from the ACS. I get an invalid cert error or cert not verified from the Iphone. The certificate is valid and I installed a intemediate CA. No matter what I try i can't get the error to go away.
Could some please assist?
mike
10-07-2009 05:07 PM
Hi Mike,
Could you please send me the exact error that shows on the fail attempt?
What EAP method are you using?
10-08-2009 06:32 AM
I am using PEAP with MSCHAP. From the IPhone I am getting the cert is not verified, When I use the IntelPro supplicant on a Laptop, it refuses to log on even though I select use "any trusted CA". I called Cisco TAC and they say I have to install the cert on all my computer, I don't believe that is correct. I am using a Verisign cert and so should already be on my computers.
Internet explorer is not having an issue with the cert, the dell wireless WLAN client does not have a problem either.
Mike
10-08-2009 06:39 AM
Check on the ACS if the root and the intermediate verisign certificate is on the certificate trust list.
Also please send me you SR.
10-08-2009 07:04 AM
Yes both root and intermediate CA are installed. Do you want to look at the ACS cert?
Mike
10-08-2009 07:11 AM
Yes,
It very strange situation.
Please contact me direct by email.
04-11-2012 08:45 PM
Hi Everyone,
I have the same issue, SSL certifciates installed on ACS s show unverified on apple devices, iphone, ipad..
Did anyone figure out what could be the problem ?
