CSA and Deny CMD.EXE
Answered Question
Oct 7th, 2009
I am new to CSA and have been trying to figure out how to block the Windows cmd.exe process outright? Is anyoneableto assist or point me in the right direction
thanks?
Correct Answer by jan.nielsen about 7 years 7 months ago
No, you should never change the built-in ruleset unless needed, in this case, you need to create a Policy, a rule module, and add an application control rule with the info i gave you. You attach the policy to the group that your hosts are in, the rule module to the policy, and generate. Just be carefull, CSA is a very powerful tool, and rules can have massive impact in your setup if you are not careful. Try it out on one machine first, this can be done be creating a group and assigning the new policy you just created to that, and then add that group to the host.
Overall Rating: 5 (2 ratings)
jan.nielsen Wed, 10/07/2009 - 23:22
  • Gold, 750 points or more
Are you sure you wan't to do that ? if so, just do a application control rule, with priority deny, all applications try to run "cmd.exe"
Jan
niall-wilkins Thu, 10/08/2009 - 14:01
Thanks for the response. So do I just modify one of the existing ones? If so which one do I select as I see about 4 of them from the Desktops - All Types -> Combined Policy Rules. I have included a screen shot
Correct Answer
jan.nielsen Fri, 10/09/2009 - 13:22
pmccubbin Fri, 10/09/2009 - 13:51
  • Silver, 250 points or more
Jan,
You are spot-on. Never change a default rule whether it is CSA or MARS. If an application SA gives you the option of adding a new policy or cloning an old one (MARS) then you should take it.
A "5" from NYC.
Cheers!
