upgrading ios on 4500 Supervisor II+
Answered Question
Oct 7th, 2009
I am working at a client site and I need to upgrade the IOS running on a Single Sup II+ engine running in a 4500 Switch chassis. I have searched Cisco specific to the 4500 and I do not get anything back that is specific to performing an IOS upgrade on a Sup II+.
I had an issue with this the last time I tried it about a year ago. I want to make sure I do this properly this time.
Correct Answer by Edison Ortiz about 7 years 6 months ago
Kevin,
As others indicated, this step was included in the document to prevent customers from getting into rommon mode due to previous incorrect config register setting.
Edison.
Overall Rating: 4.5 (2 ratings)
Kevin Melton Wed, 10/07/2009 - 19:40
Step 6 in this document references setting the config register to 2102. Why do I have to do anything to the config register? The switch is currently running right now on code 12.2(46)SG with no issues. I would not think I would need to change the config register, as I am not in a recovery situation.
Thanks Edison
Kevin
Marvin Rhoads Wed, 10/07/2009 - 21:01
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
0x2102 is the default, telling the switch to load the IOS you have loaded into flash. The step is for completeness, if for some reason you are running in other than the default mode.
See http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml for a full explanation of config register settings.
glen.grant Thu, 10/08/2009 - 03:53
  • Purple, 4500 points or more
If you don't change the register it won't load the code because 0x2101 which is the default says to load the first image it finds in bootflash:. Unless you delete the current image it will always load 12.2.46SG . Changing the register allows you to add the 2nd image into flash and then use a boot statement to point to the new image.
Kevin Melton Thu, 10/08/2009 - 05:15
Thanks for your answer. I actually was planning on deleting the old code and only having it load the new code. That is why I was thinking that I probably did not need to adjust the config-register.
I remember in some disaster recovery situations, I have changed the config-register to 0x2142?... what does that tell it to do?
Thanks again
glen.grant Thu, 10/08/2009 - 08:44
0x2142 tell it to load a default running config with nothing in it . Used for password recovery , you then do a copy start to run and then change the passwords and the config register rback to 0x2101 or 0x2102.
Correct Answer
Edison Ortiz Thu, 10/08/2009 - 05:03
  • Hall of Fame,
    Founding Member
Kevin,
Edison.
