ASA LAN Based Failover
Oct 7th, 2009
I am using ASA 5540 and trying to implement LAN Based Active/Standby Failover using Management Interface. It seems that failover is possible but not the Stateful failover. Can anybody confirm me... about it that using Mngt interface I can not do Stateful Failover??
Thanks in Advance.
Adnan
savgoust Wed, 10/07/2009 - 21:53
  • Cisco Employee,
Hi Adnan,
To use the management interface for non-management traffic, you need to
remove the command 'management-only' from the interface configuration.
At that point you should be able to use that interface like any other
hth
Stefan
