Blunder made ! pls help !
Answered Question
Oct 7th, 2009
hi all. I was writing an EEM applet on IOS version of 12.4(20). Following is the applet
event manager applet backup
event cli pattern "backup" sync yes
action 1.0 syslog msg "done-111"
now as you can guess, i cant delete it. if i type
no event manager applet backup
it detects "backup" keyword and runs the applet instead of deleting it. I know i made a blunder here, how can i delete this applet ?
Pls guide me
Correct Answer by Joe Clarke about 7 years 7 months ago
You can configure the following to temporarily disable EEM policy execution:
event manager scheduler suspend
Then you can delete your policy. then configure the following to re-enable policy execution:
no event manager scheduler suspend
Overall Rating: 5 (2 ratings)
yjdabear Wed, 10/07/2009 - 21:17
  • Gold, 750 points or more
In case you didn't "copy run start" after configuring the applet, "configure replace nvram:startup-config force" may be an option to overwrite the running-config with the startup config.
Correct Answer
Joe Clarke Wed, 10/07/2009 - 21:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
