Jumbo frame on switches
Oct 7th, 2009
Hi All,
My site has a network layout like the attachment. I have already set the MTU to 9000 on both node A and node D. The switch interface connected to node A and node D are also jumbo enabled now. But my jumbo frame still cannot function now. Is it I need to enable the jumbo on the uplink(red circle in attached photo) too?
Thanks in advance.
Danilo Dy Wed, 10/07/2009 - 23:38
Yes, all interface along the path (ingress and egress) should be configured 9000bytes MTU.
Are you using switch or router? From your diagram its a router.
To avoid problem, Jumbo Frames is recommended for back-to-back connection and L2 network. If there is a L3 device in-between, make sure that the ingress and egress interface supports larger packet size, if NOT, the packet will be drop or fragmented by the router.
5 pages http://www.smallnetbuilder.com/content/view/30201/54/
Danilo Dy Thu, 10/08/2009 - 04:20
As the link stated, all devices/interface along the path should be configured for 9000bytes MTU.
